this could also mean its losing oil pressure on start up...i had this problem back when i had the standard k20 bottom end and toda cams/supertech valve train...i reckon just to be sure take it to a mechanic, leave it over night and get them to connect an oil pressure guage before they start it in the morning...this should tell u if thats the problem...if not then its probably your starter motor as other have mentioned
I agree with you but i have oil pressure and oil temp gauges lol :P
x2... also like to know how much a new starter motor costs.
ive just recently experienced this noise for the first time.... happens on cold mornings or cold nights and im quite worried... ='(
This morning I was driving to work and i heard a few grinding noises (same noise as when i start the car up), it then stopped and about 2mins after my engine light came on!!
Has this happened to anyone else? Will have to put it in for its 80k service early i think....
How much roughly would it cost for a new starter motor and flywheel?
$1400 brand new through honda..
yes ridiculous..
if you going get a new flywheel i'd recommend a Exedy lightweight flywheel as it'll be cheaper then the OEM one but it depends if your going down the path of modifying your ITR...
If you wanna leave it standard then get an OEM one...
Originally Posted by Wez_R
maybe you should let the car warm up everytime you start it up for abit?
Yes... i've tried this but turning the key and leaving it on accesories for abit but it still causes the same problem...
Oh well... im waiting for my starter to break down so my warranty will replace it..
