1100000% AGREE, very very shit indeed....you can't get any good feeling or confidence knowing your going to slow down enough !!!
AGREE
Hahaha im glad you feel the same way, they are already shit enough for what they are on the street...you could only imagine what it is like on track.........
I can agree a million % with you regarding the LSD.
Having owned an 07 FN2R to now driving a 10 FN2R, I can definitely say it makes huge improvements.
Before I'd feel car the car not turning and having less grip means loosing traction, however now the car just grips crazy.
Extremely annoying...I think you would know exactly what i meant haha.
Since I won't be seeing track that often, maybe only a few times per year, I would prefer a helical type lsd and will most likely go for an oem k20 lsd since i can source them around the $500 mark.
From your experience, did changing suspension improve your lap times on your car? Why did you choose KW over other brands available? I don't much about KW, so please fill me in!
What are the spring rates on KW coilovers? And are they idependently height adjustable to spring preload? I also noticed that there are 3 variants available, what is best suited for daily driving and some track/circuit work?
haha was no brainer really... I wouldn't touch Japanese suspension with a 10-foot pole
and these guys were the first to come out with coilovers for the FN2, so... there were no other brands available! lol
V1 is only height adjustable, V2 adds rebound adjustment, V3 adds bump adjustment
the valving is all very similar, only a matter of how much time will you spend tweaking the settings.
springs are progressive, so there's no linear spring rates per say.
also no separate height adjustment to spring pre-load. KW products are made to be sold in Germany, they have to past very strict TUV test to be deemed road worthy.
i.e. they aren't allowed to be too low otherwise some German bureaucrat (the most anal of bureaucrats) will fail the certification.
I guess that should mean something, that they are certified for road use in Germany and not "For Race Use Only"
could always just read the promo material: http://www.kw-suspension.com/us/kw_valve_technology.php
the only other alternative I would consider (at least until Ohlins get around to making their kit) is AST: http://www.ast-suspension.com/sportline2.asp?make=Honda
but there's very little info on them at the moment. Of course these suspension upgrades will improve lap times, but they are redundant without a good LSD.
I had KW V2 in my Golf GTI (3yrs ago)
They are too hardcore and I don't recommend them to you...unless you bringing a mechanic with you to track
try adjust the rear damping you will know why
and how come you set the rear tyre pressure higher than the front?
Congrats. Going on track is fun and shows all the flaws in the car's set up. Did your mate run continuous hot laps and did not cool down? Or did he just have an oil leak which caught fire?
Aaron, yeah unfortunately my mates sti had an oil leak which dripped onto his exhaust manifold and sparked up a fire. The dangers of motorsport
Out of curiosity which LSD does the 10 FN2R use?
menzy, have u tracked ur car at Wakefield? I'm curious to know other peoples lap times with and without LSD. Can u actually feel the improvement on the street? I didn't think you could as I hardly ever break traction with the already grippy street tyres. The LSD would be the oem LSD used in all k20 gearboxes
normal driving you will not feel any difference from having LSD
but when you stomp on the gas at a corner's apex you will definately feel the LSD doing its work
even on a normal right hand turn i can punch the accel in 2nd turning at 50 with no loss of traction with lsd
but turn off VSA, the car feels weird with VSA active and using LSD lol steering is wobbly...
I haven't tracked the car yet... want to break in some more ks before I even think about it.
When you say the the oem LSD, which is what? I have no idea
curious to know what you mean by that... I've adjusted my rear damping and still don't know why haha
