If you buy a K&N filter chances are it will come with the cleaning kit, however I would not use an oil-type filter if your car is equipped with an air flow meter (which I don't think yours does).
Either way, I'd recommend getting a dry-type pod filter, i.e. simota, 3a, apexi, etc.
Even just a cheap one from Supercheap will work fine.
If the filter is going to be exposed to radiant engine heat then I'd also recommend fabricating a custom heat shield for it (you'll find many DIY topics regarding this) but if you're willing to go one step further buy or make a cold air intake.
from what i've used and seen. K&N are great for a slap on filter. (like mine). once you start looking at CAI's and SRI's the other brands mentioned above are better
i've just got normal k&n pod stuck on the end of factory intake pipe. gives nice induction noise when WOT but quiet when part throttle. i bought some filter oil with mine. $8 and will last forever.
Just can't get enough of these engine conversions.
First a mini, now a civic.... Whats next??
i had the same on my Dc2 VTIR ... stock intake arm with apexi pod - the fujita pod was a little better ... but the k+n sucked balls on both my teg and civic ... it was loud in a bad way (not revvy just annoying blary) and sluggy with response
i tried generic, apexi, k+n and fujita on my civic and teg with stock intake arms ... than i upgraded the integra to full Fujita CAI and that was kik ass
the civic has a simota big tube (whale penis) intake on it now but i have a Fujita CAI Black Edition on its way so that i dont have heat soak
Wow... you sure have tried a lot of intakes!
Do you guys know how often you would have to clean and re-oil a K&N filter?
he has way to much money. i think he sells drugs to feed his civic habit.
Umm according to the box when its dirty. Lol. but i do mine each service. So roughly 5k km's.
