boys, when I roll down my driver's window it squeeks when it's about half-way. any ideas what it may be?
Try taking off the door trim & you might get a better idea whats squeeking. Probably just needs abit of WD-40 somewhere.
Need Customs Clearance? Look no further!
just got the car not too long ago so I'll search it off before I take it off. thanks
Spray some silicon spray. easy fix.
CHEAP--FAST--RELIABLE = PICK ANY TWO
where do I spray?
put the window all the way down. Then spray into both front and rear window guides, each for about 10sec's. Then go and down with the window a few times, it should work a treat.
