hey guys its a one off idea but i notice at the wresckers theres so many complete concerto's laying around and i wondered would the rear discs and fuel injection set up fit onto the ed civic shell?
go down to the wreckers and take some pictures and measurements and compare it to your ed, i know alot of mechanical parts are interchangeable but i dont know about the brakes. Good luck
The 'fuel injection setup', the intake manifold and lines should work, they're both D series engines. I wouldn't be surprised if you could swap the fuel tanks too.
in what respect? the tank? fuel lines? the tank wont fit, its a completely different shape. The fuel lines on an EG are also on the exterior, ED fuel lines are on the interior.
concerto fuel tank will not work. the filler hose attaches at the rear of the tank where as the ED is at the front. The fuel pump and lines are also on the wrong side
CRX tanks are a direct swap if you want to convert to EFI.
Brakes might fit, although if you check the DBA catalouge concertos have a specific rotor. whereas most civics with a 240mm disc all use the same part.
If you take the entire hub or arm assy it may fit.
I know this is sorta old, but where abouts are these concerto's...? What wreckers etc.
Interested in getting one for somethign different and a small project.
Cheers.
Not putting miles on your built cars is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend.
