help!
im having trouble with my eg sedan, i dun really know any technical stuff so im hoping u guys could help w this
okay, i think the problem is the clutch, but im not sure, when idling i could hear noises coming from the engine, something like 2 pieces of metal hiting each other, but when i clutch in, its gone, when driving "normally" i could hear the noise again somewhere after 2.5k or 3k rpm and above, this happens to gear 1, 2 and 3, for gear 4 and 5, the noise softens but i could still hear noises
need help asap
thx
I think your clutch bearing need replacing.
Green block gangster
Array
could be your input shaft bearing
As above......its most probably your Input Shaft Bearing........have a read of this if you want to DIY.
thx for the replies guys, btw wynode, how much will it cost me for new input shaft bearing, and other bearings that i might have to change? just curious, how long did u take to do all of that?
what's the noise sound like? Might be best to take it to like Midas and ask them for an analysis and a quote. I believe that they have a free quote system.
As you haven't really said what type of noise it could be a number of things, from exhaust vibration to input shaft bearing.
Get it diagnoised properly then your can get quotes on the cost.
im pretty sure its not exhaust vibration, i could only hear the noise when idling without clutching in, and when driving above 2.5-3k rpm for gear 1, 2 and 3, the noise is really noticeable, for gear 4 and 5 the noise is not as noticeable
im really sure it doesnt come from exhaust vibration, but yeah i think i will try to follow your advice, thx man
for others, im still seeking for more opinions on this, so pls post a line or two, thx guys
