Results 1 to 4 of 4
    Jul 2010
    Sydney
    DC5
    DC5 2005 shocks/springs in 2002 model
    Hey guys, I've discovered come conflicting statements around the place, was hoping to learn once and for all if DC5 (2005) skunk2 springs will fit in a 2002 model.
    Skunk2 seem to have a different model code for 2002-04 models and 2005+
    This seems strange though I would have though it woule be comapatiable
    Other question is if I replace the shocks AND the skunk2 springs from a 2005 DC5s into a 2002 DC5 base if it would work. Has anyone had experience with this???
    Cheers,
    mike
    Newcomer Array
    Sep 2008
    Brisbane, South
    EG5 VTI
    Yes, as posted in another thread going on at the moment, the springs are different between 02-04 and 05-06 models. 05-06 front springs are inversley wound (mirror image of each other), and 7mm lower in ride height. If only replacing springs, you need the ones appropriate for your year model.
    Also, if using lowering springs with stock shocks, the shocks will wear out rapidly and the ride will be pretty poor.
    Feb 2008
    Sydney
    DC5R
    No. The springs from the Facelift Models (05-06) wont fit the Prefacelift Models (02-04) and vice versa, as the springs are wound in the opposite direction.
    You can however, swap both the shock & springs from a Facelift Model into a Prefacelift, and vice versa.
    Jul 2010
    Sydney
    DC5
    Ok sweet, might get myself a springs/shocks package.. apparently skunk2 springs are quite well matched to stock springs compared to other brands.. and when the time comes for new shocks so be it...
    PS. are 02-04 and 05+ skunk2 springs the same height? I'd imagine so
    Cheers
