Well you can ask Danny soon. He's planning on doing the conversion. Apart from that I have heard that it is simple. Hardest thing really is wiring I guess...
Hey mate.. You can get a front cut from about $2200 to about $3000 depending on where you go.. You might need to pay interstate shipping fees which may cost up to $300 again depending on where you go. As for labour, if you can do it yourself, its gonna save you quite a bit. All parts needed for the conversion will be in the front cut unless of coz the seller is dodgy and starts removing things like the radiator, distributor etc but most should be fine. If you are gonna get a mechanic to install it, the price varies.. its best that you change a new clutch and also new timing belt when u do the conversion. Save you money in the long run. If you need any more info, pls pm me.. You should try to set aside at least $4500 (if you getting a mechanic to install it)
