Results 1 to 5 of 5
    Squealing noises from the engine bay
    Hi,
    Whenever I start the car, a squealing noise comes from inside the engine bay but when i'm in idle it lessens and when I rev, the noise is even louder.. Can't seem to find where the noise is coming from.
    Dec 2008
    N/A
    i recommend you check the tension of your drive belts to see any loose and maybe spray some WD40 or put some dri lube.
    cheers
    Alright i'll go check them out now and make sure they are all tight.
    AC belt was loose, thank you so much!!
    Ozhonda Subscriber Array
    Jun 2008
    Doncaster, Melbourne
    DC5R with a JDM K20A
    Quote Originally Posted by davidha91 View Post
    cheers
    Do NOT spray your belts with WD40. If anything spraying water will help you find the source of the squealing but spraying WD40 will fix it for about 5 minutes and it'll come back worse. In that scenario you'll have to replace the entire belt itself rather than just tighten. (Experienced this myself)
