Hello, Does anyone know what amount of torque the sump bolts need to be done up to on a DC2R and what kind of sealer is recommended? Thanks in adv.
44Nm (for EG, could be same for DC2R) and use a new crush washer. no sealer is needed
[h=Massive EG6/DC2 Part Out (majority brand new) http://www.ozhonda.com/forum/showthr...y-brand-new%29]2[/h]
I think he might be referring to the sump to block bolts, not the drain bolt. I got no idea on torque, but i've heard "hondabond" thrown around as the recommended sealer.
that shit is mad expensive from honda dealer. hahah permatex grey is the same i think.
S P A M | W O R K S With our special rotational tires, it will allow you to drive very fast. - JK Tyre
Ok I've found some documentation online. Seems that it's 12Nm and no sealer required just a rubber gasket. The sump bolts need to be done up hand tight and in an order being the 2 middle bolts first then so on, cant remember the rest of the order off the top of my head atm.
