Does anyone know if you can use the Buddyclub N+ coilovers for a EG/DC2/R on an EF8 CRX with DC2R rear LCA? cheers in advance.
yeah if u already got dc2r lca i dont see why it shouldn't. for the fronts just need to fit your forks...
WINTON PB - 1:48.9 EG5 1.6L SOHC
gotta use dc2r/eg6 forks and lca's. someone has told me that under full lock, the front forks will hit the driveshafts.
This is true, you can run them on ef8, but just be prepared to have quite a bit of shaving on your drive shafts due to clearance issues on the front wishbones. My advice is find some EF8 sussy
Originally Posted by vampzzz gotta use dc2r/eg6 forks and lca's. someone has told me that under full lock, the front forks will hit the driveshafts. which forks hit the driveshafts the stock or the dc2r/eg6 ones?
dc2r/eg6
I run dc2r stock sussy with front dc/eg forks and rear dc2r/eg6 lca's. in my ef8. no problems what so ever. never had the shafts hit the forks. the forks don't need to be from dc2r/eg6. any dc/eg forks will do.
