Page 1 of 2 12 LastLast
Results 1 to 12 of 14
    Dec 2003
    Sydney
    Honda Civic Coupe 97 VTi
    Hey guys.. NEED HELP!
    have any of you guys heard of a brand called Premiere DEH-750mp. Its apparently a Pioneer DEH-7550mp.. everything similar but the only thing different is the brand?? I've got a link to it.. please help and tell me that I can install this in my 97 civic coupe!
    http://www.pioneerelectronics.com/pn...006488,00.html
    It's an overseas model. Are you importing it?
    Disabled Array
    Aug 2003
    Glen Waverly
    Type-MO
    if it's from japan, you'll need that FM convertor thingy if you want FM radio
    Dec 2003
    Sydney
    Oh ok. I bought it already from ebay.. :?
    Took a risk, but this guy was a good seller. I've got the goods and everything, packaging was excellent.. I went to install it this morning but its not working.. fuses are ok, rewired and secure the power but doesnt seem to work..
    Is there any other major differences from pioneer and premiere that i should know?
    Power volts / wiring etc..
    Did it come with a manual?
    Dec 2003
    Sydney
    Yeah all it has about voltage was that it should b hooked up to a 12 volt battery.. not much else..
    was wondering if anyone has installed one themselves and found any sort of different steps required when hooking one up
    I still love HONDA! Array
    Nov 2003
    Melbourne
    Black8
    is it totally not working (as in cannot be turned on at all)? Is it grounded? Are all wires from the wiring loop connected? Maybe the wires was connected wrongly?
    Worst case, take it back to the seller and say it didn't work.
    euro77 by Jimmy (toE)
  8. #8
    Dec 2003
    Sydney
    Yeah its totally not working as in no power and can't be turned on.
    I've only connected the neccesarry ones for now which were:
    - AC+ Accesories Power
    - Battery Wire
    - Ground
    - Light
    am i missing something?
    Also if i hook the old radio back up (stock radio) works perfect..
  9. #9
    Aug 2003
    Accord Vti-S turbo
    have you hooked up the ACC (accessories) wire? If not, the HU wont turn on
    The wiring/voltage will be the same, they are all designed to run on 12V negative earth power systems.
    EDIT: i posted just as you did :P
    With those hooked up it definitely should be working. Checked the fuse? It should have one...
  10. #10
    Dec 2003
    Sydney
    Thanks for replying.
    I checked fuses.. The one in the engine bay for Battery Backup, the one near the driver seat which is the radio fuse and the one in the head unit itself and its not blown..
    hmm.. mayb i should get some audio specialists to take a look..
    man im worried now.. shit
    i guess i deserve it
  11. #11
    Yeah, take it to an audio store and see if they can locate the problem.
    This is why i never import audio/visual gear and strongly advise against it. You don't have much to fall back on.
    Good luck getting it to work.
  12. #12
    Nov 2003
    Gold Coast
    S15
    Get a multimeter out and check that the wires get 12 volts when they should. Ie constant has a constant 12 volt charge, ACC only when ignition is on etc. Tried running a fresh ground wire? Where bouts you located?
    Cheers,
    Javed
