Hi there! What gauges I can put into my non turbo car?? Water temp?oil temp?oil pressure?vacuum?boost I don't think so....volts??
vaccuum is a waste mate. If i were you i would run oil pres, water temp, and if you have a decent stereo run a volts gauge to. Or run none
'05 Accord Euro Luxury 'Sports', Hah! Looking For Wing-less CL9 Graphite Boot - Willing to discuss trade for boot with wing!
vacuum is only a waste on a stock NA, a built NA i might need to monitor it. but yeah if its just for looks just go Oil temp and Oil pressure, dont get water temp if ur stock 1 works just fine.
Car: 05' Civic Turbo Car: EK 97' Motor - D17 Motor - B20T Winton - 1:47 Winton - 1:46 7th Gen Melbourne #1
the stock water temperature doesnt give you a reading in units... getting a proper guage that reads in degree's will give you an accurate readout. However, i'd rather have oil temperature anyway, water temp is a by product of oil temp
- not removed by choice! - waiting for the next update to the saga http://www.ozhonda.com/forum/profile...=ignore&u=6316
Unless you do track work. I wouldn't waste money on getting gauges.
______________________________________________ F20C Clubman Build
Clocks are cheaper and would serve a better purpose in a stock car You could have one for Melbourne, one for Tokyo and one for New York... JDM, AUDM, USDM =)
there is also oxygen sensor gauges but seriously.. gauges are a waste of money and expensive and your just increasing the chances of someone stealing it by having them..
Originally Posted by Kiz_EG6 Clocks are cheaper and would serve a better purpose in a stock car You could have one for Melbourne, one for Tokyo and one for New York... JDM, AUDM, USDM =) +1one
