Hey guys... Ive got abit of a problem on my hands.
Im in the process of swaping in a B18c2 from my crashed 97 integra into an 1995 Gli Civic( AUTO trans) hatching back.
I read millions of times all you need is B series mounts. And so ive collected myself a full set. They are all from vti-r dc2 im pretty sure with my right engine mounts being from a typeR this being the only exception...
I lowered the engine in with its mounts down into the engine bay. We attached the very bottom rear gearbox mount first as it was the hardest to get in.
I then raised the engine using the crane and a jack under the gear box. The right hand mount slid into into spot. HOWEVER on the left hand side the gearbox hit on the rail before it was in the mount completly. I cant get the motor into its mounts before it hits the rail.
Also with the engine near the mount it looks like the motor sits very high....
You can also see that even if one side mount was in the other wouldnt line up.
With the right hand side mount in it looks like the motor is on an angle compared to the mount. As the mount is angled to the font of the car and the motor mount is straight...
Sorry I dont have a photo of the left mount in. But with the mount removed and the engine lowered about an inch it looks ok.... the gear box sitting under the rail and the motor doesnt sit as heigh...
With the motor sitting in its right hand mount and the left pulled up as far as it will go. It looks like the motor sits way to heigh... I wounder if the bonnet would close....
CAN SOME ONE PLEASE TELL ME.
Is the gear box ment to slot into that litte recess on the rail ? or sit under it? ( on the left hand side)
Do you use B Series mounts all round?
Is there any difference between B series mount? DC and say eg6 mounts?
Is there any code on the mounts I can tell if they are deff B series ?
I dont think it should matter that the EG was auto and now im sticking in a manual....
I think it can be one of two things.
Either I have the wrong mounts..... They look the same as my old teg ones.... and they have 95 teg written on them...
Or two. Somthing got bent in the crash. However a motor cant bend..... The head/block and gearbox are alloy. Alloy doesnt bend....So my only thought is that the metal bracket on the right hand side of the motor might be bent.... or the big rear bracket gearbox might also be bent.. this sitting the motor on a funny angle...
HOWEVER this doesnt explane how the motor sites this heigh and that the gear box hits before it gets into the left hand mount...
Im sorry this is all so hard to explane.
Why wont it fit ;(
