try reduce the IAC duty cycle in SManager under: parameter->idle
or reduce the water temp compensation under: parameter-> fuel compensation
--hondata dump too much fuel for cold start in my case if leave this unadjusted from "stock-itr" map.
maybe uncheck "closed loop operation" if you are using stock O2 sensor setup.
adjusting the above works for me...
