Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 39
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Quote Originally Posted by RandyRhydah View Post
    ahh ok i see... will consider gt2871 when upgrading then cheers
    I'd go bigger if you want good safe power GT30
    I think the gt2871 is great for B16's and that's what I'm running but B18's love GT30 IMO
    The gt2871 will still work well on your B18 though
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    Jul 2008
    Queensland
    EG Hatch
    put the resistor in today... still leaking oil thought
    its coming from around the sump and a little bit higher and it only leaks when the car is turned off. if its idling it wont spill a drop
    its not the sump gasket because i replaced that when i first noticed the leak... the shop that welded my bung in used silver solder so maybe with the rapid heating and cooling it could of warped my sump?
    just throwing out random ideas now
    FIGJAM
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    -8 or -10 oil return lines?
    I dropped my sump on the weekend to fix my oil leak.. took me like 5 tries
  4. #16
    Jul 2008
    Queensland
    EG Hatch
    not 100% had -8 but replaced it with one a little bigger so i assume -10? its free flowing and isnt kinked or bent too much... what do you mean it took you 5 tries was the gasket not seating properly or bung not welded properly?
    FIGJAM
  5. #17
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Kept leaking through the gasket time and time again.. finally got her seals..
    Re-flattened all the surfaces and cleaned, new gasket with liquid gasket and she's sweet now
  6. #18
    Jul 2008
    Queensland
    EG Hatch
    hmmmm i wonder if thats worth a shot with me aswell... hate taking the sump off lol
    what liquid gasket do you reccomend?
    FIGJAM
  7. #19
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Tell me about it!!!!!!!! I need to remove the turbo/manifold/dump pipe/AC fans and some of the exhaurst to drop my sump
    I just used the high heat red stuff from auto one, the tubes so foked I can't even read the name it it sorry lol
  8. #20
    Jul 2008
    Queensland
    EG Hatch
    oh sht lol i dont have to take the manifold and turbo off to get mine out.. i feel better now
    thanks for the info sorry to be such a pain ill give it a go tomorrow arvo and fingers crossed it is my sump...
    FIGJAM
  9. #21
    Jul 2008
    Queensland
    EG Hatch
    replaced the gasket for the oil drain fitting on the turbo because it was moist... also went nuts with the toyota black sealant stuff around the bung on the sump and the leak slowed down alot.. will have to get it rewelded and hope for the best
    FIGJAM
  10. #22
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    I've got bolts welded to the inside of the sump so I can tighten the flange via screws if needed. plus then I can remove or change the flange should I need too
  11. #23
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    rem to make sure the return line is lower, as it is gravity returned. Any pressure in it will cause build up in the turbo and turbo leaks
    Evo IX - THE FINAL EVOLUTION
  12. #24
    Feb 2007
    Brisbane - Northside
    EK4K24
    Quote Originally Posted by Limbo View Post
    exactly what i was going to say... but in reverse lol u need the return on the sump higher...dont want it returning into the oil...
    i was told this by Mike Vine at Mike Vine Turbos, i purchased a kit and its built up back into the turbo it had sat around and
    siezed.... i managed to fix this though...
    Vince
