18 x 7.5 rims
Do you guys reckon 18 x 7.5 rims will look aggressive enough, or should i go 18 x 8?
Mods: Pioneer Double DIN GPS, K&N Typhoon CAI, Buddyclub N+ Spec, Topspeed Headers, Skunk2 Catback Exhaust
You also need to consider the offset. If you go 8" and your offset is weak, eg > +40 then it will not look very aggressive.
Check out the low wheel offset thread for more info.
yeah i had a look..i was thinking 18 x 7.5 or 18 x 8 with an offset of 45? that would be alright i'm thinking
It depends on what you think is alright...if you want a flush look then you need a lower offset closer to +30.
18x8 +45 would be pretty easy. +30 or so would look a lot better.
18x9 +35 is a good fitment. not aggressive as. but enough to kill wheel gap.
Perfect fitment I believe is 18x9.5 + (25-30) for the rears, fronts 18x9 + (25 or lower). It would sit real flush. Check in the flush euro section, plenty info there and pics
..OzHonda Spam Crew..
..We Welcome You Abourd!..
Quoted for effect ~
ah ok yeah could you give us a link?
so +30-35..is that hard to do?
18x9.5 +25 sits 100% flush at the rear when dumped, natural camber is perfect.
the front is up to you depending on how aggressive you wanna be. i wouldnt go any narrower than 18x9 +30
3TripleZero S T A N C E | W O R K S
got mine for sale pls pM
WORK VS XX 18 inch
