Im having a little trouble with holding boost in my car.
The set up is:
DOHC ZC
GT2560R
Log Manifold
2.5" exhaust
plus more but i think this is the most important.
The problem is once full boost hits at around 4000ish it will creep up and extra 2psi by red line.
The same thing has happened on boost settings of 9, 6 and 4psi each time only increasing by 2psi.
At first when it peaked at 11 i swapped the wastegate actuator over to a lower psi adjustable garret one for the next two settings.
Im hoping to have it tuned gain very soon and wanted to fix this problem before then.
Any ideas are appreciated guys!
Luke
