Results 1 to 11 of 11
Hybrid View
    need help buying 5th gen prelude
    Hi guys,
    I looked at a black 1998 prelude vtir, auto, bodykit. With about 130,000kms. Asking price is 7k. Body is ok, interior is immaculate. But it feels like it is slipping 1st and 2nd gear, if i drive slowly it is ok.
    Should I do it?
    Oct 2010
    Townsville
    BB6
    no. apart from the slipping issue it's an auto...I guess that's handy if you're in a big city but still, manual > auto. although you could buy it and just convert to manual...if you have extra $ lying around.
    Dec 2009
    Canberra
    97 Integra
    I have heard the early BB6 models have a lot of issues with the automatics, so maybe should stay away. Anyway, with a car like a 5th gen Prelude you really want it in manual.
    May 2008
    5th Gen Prelude
    I would never recommend getting an auto BB6 in any case, let alone if its already showing signs of failing.
    I have a manual and I drive in the city. It got to the stage where now I dont even think when I drive. Its piss easy to drive in traffic once you get used to it.
    i second gumus89's post, also i've also heard that alot of the bb6 models have auto transmission problems don't quote me on the validity of this information though hahah just what i read around forums
    May 2008
    5th Gen Prelude
    On the american forums its a notorious failure. Some fail early, some fail late, some not at all. But the chance is just too high and the car too slow anyway to risk it.
    Someone I know has an auto thats fine, drove a manual and said it felt like a different car.
    I was like zzzzzzz when I drove my cousin's 2000 model auto bb6...
    :P
    Manual ftw!
    Aug 2007
    Brisbane QLD
    ED-209
    As below. Buy a manual. (I'm a purist and i hate autos.) It's too risky with that bb6 auto transmission
    Jul 2009
    NSW
    prelude
    yea you should get an manual
    from experience i was given a prelude as a gift as a first car from rents and after proberly 6 months the transmission died and cost about 4 grand to fix it at nevilles at bankstown
    this was just replacing the clutches that was gone and an active torque steer that was a reconditioned one anyways
    althought it cost abit they did a good job and i have 12 months warentty on it
    btw it started off by sliping in first when the engine was cold then turned into a big problem afterwoods
    Nov 2009
    sydney
    Prelude VTi-R ATTS 99'
    its not that im against autos. but the BB6 are known for a terrible trip-tonic auto gearbox. before you but it. check everything you wouldnt check.
    check the walls where the wheels are, if theres like pieces of rubber stuck all over it, most likely burnouts. so the engine might not be in top. so check the engine.check if theres any bends to the chassis at all, if something doesnt match at all, most prob in an acident also such as cracks in the radiator, piping and fluids.
    also check underneath the car, check if theres any holes, its got a bodykit? is it lowered? if it isnt lowered, most prob u wont find any holes, but check the kit for scratches and home repairs. if its got a sunroof, move it up and down. some usually bounce when opening but its cause of a build up of dirt in the rails, or could be more serious, but mos prob just dirt.
    also when checking the tyres, check the inside of it, mostly wears out there more than anywhere else.
    now being VTiR your gonna want to try out the vtec. let the car warm up before it, cause the ecu wont let it engage, check if theres a massive amount of black smoke comming out the back when it hits vtec, if there is, its giving you the idea, that the oil filter needs changing because VTEC lives off your oil and it could use a bit so check oil level.
    also about smoke, check if it blows any smoke, white=BAD, Black= ok cause bb6's are made to run rich anyway so dont worry.
    ACTIVE TORQUE TRANSFER SYSTEM
    ^^^ great advice!
    Vti-R
