Results 1 to 12 of 13
Hybrid View
    Apr 2006
    Adelaide, SA
    Integra GSI
    Changing Battery on Honda Jazz - Transmission Warning - Must be Done by Honda?
    Hey all the battery died on my Honda Jazz and supposedly it needs to be changed by someone at Honda according to the warning sticker on the car otherwise it will mess with the transmission?
    Is this true? Can I REALLY not change it myself?
    Thanks for your help!
    AusTEG.com
    Australian Integra Community
    Quote Originally Posted by Q_ball
    OMFG
    Dmac > panda lol
    Team Lonely Driver - #044
    Sep 2008
    Ghettoland
    Isabel
    Not too sure on this one but I changed the battery on my mums auto Jazz and it was fine =/
    Honda put stickers like that everywhere though including what fluids to use etc..
    Its up to you if you want to take the risk but Honda fluids are always recommended but not too sure on the battery part man =/
    Samm928: I must say your the biggest noob kid ever.
    that is all.
    WTFPWNED
    Secretly trying to make my daily into a warrior without my missus knowing...
    Apr 2006
    Adelaide, SA
    Integra GSI
    Ahh ok thanks dude! I can't see why I can't do it myself....Recalibrating seems to be easy anyway!
    AusTEG.com
    OMFG
    Dmac > panda lol
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    the warning is for the cvt as once the battery dies you need to recalibrate it
    honda has the correct tools to do this
    if you leave it your cvt will eventually go
    go buy a oem honda jazz battery only 120 bucks
    Green block gangster Array
    twin GX160's
    as above
    if its not done correctly it can kill the start clutch
    I remember my mechanic saying you have some steps that needs to be done so you can reset the car or else if driven and these procedures are not done it will kill the CVT.
    Feb 2009
    Guildford, WA
    Jazz VTI auto
    Cool Changing battery in Honda Jazz CVT
    You can change the battery yourself BUT you must keep the charge up to the system or you will lose the settings for your CVT transmission. You can do this by putting jump leads from your new battery to the lead to your old battery then disconnect the old battery and replace it with the new one, BE CAREFUL not to disconnect the jumper leads at any time untill the car leds are in place on the new battery and secure. You can also use a plug in to your cigarette lighter that is connected to a jump start pack. The key MUST ne turned on to the running position and this will power up the system. I have this and it works well. You don't have to worry about the jump start leads comming adrift during the changeover. I also turn on the radio so I can check that I don't lose power at any time.
    If you do lose power to the system and lose the settings on your CVT, drive the car carefully to a Honda dealer to get the CVT reset. Don't accellerate harshly, just ease it off the mark and be carefull not to accellerate quickly at any time during the trip. It costs about $80 Au for the reset. Good luck!
    You're about 5 years too late...
    Nov 2007
    EP3R>AH>EK>DC2
    Quote Originally Posted by DreadAngel View Post
    brah it's still a good post to help the future Jizz's.
    SPAMMAPS
    Carburettor|Nation
    Dec 2011
    Sydney, Aus
    '93 EG Si
    Is this for only CVT Jazz's?
    Currently officially unofficially Ozhonda's vinyl sticker distributor:
    1 Small 150 x 29mm: $6 posted
    1 Large 250 x 43mm: $8 posted
    IG: thenameis3k9
    twin GX160's
    All Honda CVT cars
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    Infact there has been many situations where I would've had the battery out of the Jazz for long enough for it loose charge. Installing the valve cover gasket was a bitch.
    Only time I reset the CVT is when I flush it every 15-20K KMs.
