Valve Adjustment
Hey Fellas,
Just wondering whether anyone had adjusted their valves themselves? I want to have mine checked, as it seems to be a little bit noisier than normal (nothing major, but I notice it so better to check it). If my valves aren't out of spec, the next thing I'll look at is the Timing Chain Tensioner - probably do that mod people do on S2Ki.
I just want to know how people went about in doing so and anything I should look out for, as it seems like a very straight forward process. I am slowly trying to eliminate any abnormal sounds that may be heard, because I think it's quite embarassing... lol
Recently changed my idle/tensioner pulleys, and have noticed it dampened some of the whining noise, but I suspect the other pulleys are a bit worn too (Alternator/Water Pump) so I may have them all changed out as well. Mind you, the serpentine belt was still pretty shmicko. I just hit 100,000kms. ):
Any help or tips would be greatly appreciated.
Peace.
Yes many of times, Actually i'm doing mine tonight! they're easy to do, you'll need the specs and to follow the service manual on the correct method and sequence. I had mine done and the engine sounded like a diesel, so i sourced a service manual, decent feeler guages and done them myself. Tapets that are need adjusting can be easily diagnosed through the consistent ticking/taping sound, the chain tensioner is more inconsistent and can become loud on decel, hard to explain, but you can tell where the noise is coming from, front = generally tensioner, top = tapets. Good luck.
CHEAP--FAST--RELIABLE = PICK ANY TWO
Cheers mate, just what I wanted to hear! I actually have one of them valve adjustment tools (the screw driver inside a socket set with a handle) so it should be fairly simple to do. Do you mind posting me your specs? As surely, it worked for you.. lol I might tackle it tonight also! My noise isn't really a noise, I think i'm just being picky.. But meh, doesn't hurt to check!
Peace.
I'll post them up tonight, specs are as per service manual. You need to understand that the rocker arm needs to be placed on a certain point of the cam lobe, so that the adjustments are done correctly (you'll need to manually spin the crank in the right position to achieve this, also easier with the spark plugs out!).
Yeah, I understand that there needs to be 4 different cam positions to be able to measure each clearance etc etc. I just want to cross-reference the specs your using to be sure we're talking about the same thing.. Shouldn't take more than an hour to do IMO.
Yeah sweet, thought i'd ask anyway. Usually takes me about hour to do and re-check.
Thought I might as well ask you since your a mechanically inclined.. Have you ever experienced a sort of "Alternator Whine" type noise in your S? People of S2Ki say that it's common for the idle/tensioner pulleys to get noisy over time.. I've replaced both and I still get the whine, althought noticebly quieter it's still there! It sounds like the gearbox ish, but mixed with engine sounds if you know what I mean, generally hear it on gear breaking next to a wall... It whines down with RPM.
I might change the Compressor Pulley and Water Pump Pulley too, but I thought I'd ask....
JAP, since you're doing yours you can do mine too lol
Need Customs Clearance? Look no further!
Yeah mines got heaps of whines, but i've just zoned out to all of them over time, a whine that's engine speed related could be a whole stack of things, either motor or gearbox related, whines are a hard thing to diagnose when it's only very minor, you really need to try and pinpoint the location, however if it's only minor, i personally wouldn't worry to much about it, as most early models are well over 100,000kms, so it's fair to expect a few noises here and there.
Anyhow service manual states, Intake 0.21mm - 0.25mm & Exhaust 0.25 - 0.29mm, my choice has been to always run the larger gap, as it's more suited to hotter engine conditions.
Sure Si1, if the price is right.....LOL
Make sure you gap with a stone cold engine.
Deano.
Is there anyone in Melb who'd like to show me how to do this? I want to DIY but would like some supervision the first time
I also need a service manual. I've got one on the comp but it's annoying to use.
Case of beer for anyone whos willing!
I'm planning to do it over the weekend, so I guess I can try take some photos for a possible DIY write up? I know there's heaps of them on S2Ki etc, but I think they speak a different language in the northern hemisphere. Ie. Bondo, Inches, Feet, PITA, etc LOL
