I am just studying how to change the fuel filter , and the manual goes into removing the console and the handbrake and to get access to them you have to strip out the centre of the dash. This looks incorrect as if someone did an incorrect link.
When I did a search, someone mentioned removing the passenger seat.
Has anyone changed a fuel filter? if so how did you get access to the top of the tank?
It will save me time to find the correct procedure as to me it seems crazy that you have to remove the centre of the dash to change the fuel filter. The special tool bit is no worry as,I have found that you can undo the big "jam top" by hitting a screwdriver with a hammer against the raised edges . I have done this successfully on my Range Rover.
Regards Philip A
