Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 44
  1. #13
    Mar 2010
    Adelaide, Australia
    '01 WRX
    Quote Originally Posted by viinnh View Post
    hey mate is it true you cannot use stock cat ?
    i had after market headers for my d series and 1 of the reason i sold it because i have stock cat, flange dont line up + after market headers are using donut gasket ?
    that would be incorrect i used my stock Cat with these header, everything lines up perfectly and it came with a new donut gasket.
    OVERRATED TO BE UNDERRATED
    LOLNOPE!
  2. #14
    May 2010
    Melbourne
    2000 DC2R
    If your getting headers, you should get the whole system including cat. Just a header gives a tad of a benefit. The whole system working together is what gets you results. These headers will attach to your stock system. Yes the headers come with a donut gasket and gasket for the block and header attachment. Perhaps you purchased headers for a d17 or received the wrong header and that's why they didn't line up.
    3 guys walk into a bar. The first guy told the D to get a B series.The second guy told the B to get a K series. The last guy told the K to fk off just get a V8 mate.
  3. #15
    Feb 2009
    Hunter Valley
    B18EG|EG6|EP3
    I bought these ages ago - Made a huge difference (with a metal high flow cat)
    Great bang for buck
    The only problem I have with these, is that the exhaust gasket is an uncommon shape, and i blew one...been using gasket goo ever since
    My EG5 build
    "Try to move in with a hot easy gurl. I've got a mate who does his house mate when he gets drunk. This way you can cure some of the loneliness and also save $$$ on prosties. Just remember to act like nothings happened the next day because if you get attached your laterz mate."
  4. #16
    Mar 2010
    Adelaide, Australia
    '01 WRX
    Quote Originally Posted by will13 View Post
    Been fine just with the gasket glue?
    LOLNOPE!
  5. #17
    Feb 2009
    Hunter Valley
    B18EG|EG6|EP3
    Yeah been fine. But you have to be very careful not to hit big bumps or speed humps again because once it hardens, you can crack it and then you will have a really annoying exhaust leak
    My EG5 build
  6. #18
    Jun 2006
    WA
    EG+CL9
    theres a full DIY and review for these in my build thread
    D15b Turbo EG Sedan Build + CL9 Lux N/A Build
    http://www.ozhonda.com/forum/showthread.php?t=127680
  7. #19
    Nov 2010
    WESTSIDE melbourne
    Ekay
    where exactly did u buy these headers may i ask?
  8. #20
    Mar 2010
    Adelaide, Australia
    '01 WRX
    LOLNOPE!
  9. #21
    Newcomer Array
    Sep 2009
    Melbourne
    Hi, I just installed the headers in my car today and I've got a question.
    Are your headers flush with the cat where you have the two spring bolts?
    Because mine looks like this:
    I've tightened the bolts/nuts up as far as they will go and I still have a gap and part of my gasket is exposed. I don't know if I have an exhaust leak but my car does sound a bit different since installing the headers.
    I've got the same car as you btw, 1998 EJ8.
  10. #22
    May 2010
    Cabramatta,NSW
    DB6
    does your cat support the donut gasket ? or is it those flat ones ??
    DANGSdriveway
  11. #23
    Newcomer Array
    Sep 2009
    Melbourne
    Uimm, it's the stock cat and it's a doughnut gasket, it came with the N*Power headers.
  12. #24
    May 2010
    Cabramatta,NSW
    DB6
    na i meant your cat mate, some cats dont have the cruved groove for the donut gasket to go on.
    happened to me so i just sold the headers.
    DANGSdriveway
