Change the front suspension and install the straut bar and anti-roll bars
oem suspension is fine as it is for comfort, strut bars and anti roll bars are meant to reduce body roll when the car is going around corners but will not add to comfort nor reduce the bounciness
my jazz is currently on stock 15" alloy rims and stock suspension. i normally keep 34psi rears and 32 fronts. what do you guys recommend?
First of all, I believe you have the pressures the wrong way around. Should be 32 FR and 30 rear according to the door jam on a 2008 VTI-s on 15".
Second, I run 34 & 34 on the stock 15"s. Yes it rougher than it needs to be, but I do it for steering feel and fuel consumption. I think 30psi all round will be smooth, but do not go lower for safety, traction and fuel consumption concerns.
Third, get rid of extra junk (weight) you are potentially carrying in your boot and back seat.
Fourth, if your Jazz is the one in your Avatar, then it is definitely lowered, causing the rough ride.
I find my 06 VTI is smoother, and less bouncy, with a full load of passengers.
haha same, i guess the added passengers help weigh down the rear although guard rubbing gets annoying sometimes
34/32 is abit high for stock wheels, like holy frog says try 30s or even slightly lower like 28, it will increase fuel consumption and sacrifice abit of handling but you should see overall comfort improved. If anything get some massive tyres like 195/65/15 should make it a smooth ride
I've had Cusco VACANZA coils in my car and they were awesome. Not too stiff too. They're designed to give you the ability drop ur car and keep a nice ride comfort. You should look into a set if u want better handling (Much better compared to stock) and still want a decent ride comfort.
I also had a bunch of struts in my car but that only made the body feel more ridgid. hope that helps.
Post Quality > Post Quantity
Loving HID and LED installs! Feels free to ask me any questions
Installs done to: Jazz's, Civic's, Euro's, Skyline's, Silvia's, Commodore's, Corolla's, Mazda's
BUDDYJAZZ srsly stop trying to sell your car on here, get some rep or something. kinda annoying seeing you bring old threads back so you can sell your car.
