Aim: Fit a diy cup holder to ek center console
Required:
Phillips head screwdriver
6gx25mm screws
Single din cup holder (about 15 bucks on ebay)
Steps:
Step 1: Remove these 3 screws and repeat the process on the other side then remove the rear console piece by pulling it backwards. The front section will now come out easy.
Step 2: It should now look like this. (minus the cup holder as i fitted this before i wrote up the diy)
Now remove the 4 screws shown in the picture on each side and this section can be removed
Step 3: Now that you have this out its time to pull it apart by taking the screws out shown below
Step 4: Disassemble the single din cup holder,remove the tray from it and the plastic front piece that i have put the red around
Step 5: Now use your 6gx25mm screws and a screwdriver to screw in as shown to secure the tray (no drill needed as the plastic is soft enough to use the screwdriver)
Step 6: When you're happy with the fitment just put everything back together in reverse of the way you pulled it apart and it sould look something like this.
Other comments: I could have put this in the single din opening down the bottom but then it probably wouldn't even fit the smallest of drinks.
By doing it this way almost any drink will fit including a large macca's cup
