Results 1 to 8 of 8
    Newcomer Array
    May 2010
    Melb
    92 Civic SI, sedan
    Civic 92 si sedan, manual. NOT USE CLUTCH??
    Hello,
    I've got a friend who owns an old truck, he says he uses the clutch for first gear and thats it.
    once its going he will just shift though the gears without the clutch.
    Is that possible with mine? (description ^)
    and why?
    Jul 2009
    Mango Of The Hills
    EG8
    Yes it is possible. It's called rev matching, it takes a while to learn and well it's only really possible (for street warriors) when doing under 4k RPM switches. It's easier to switch up than to switch down. But in all honestly, it's not really needed for a street car, it's more like an emergency thing if your clutch does fail one day. But in saying that, learn it but just try not to grind syncros
    Why don't you tell your daddy to comb his damn hair, look like some spiders is having a meetin' on his head.
    Newcomer Array
    May 2010
    Melb
    92 Civic SI, sedan
    Quote Originally Posted by xclusive_eg8 View Post
    when you say that. how do I know what revs to change at
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Don't bother doing it.
    But basically if your engine is rev'ing at the perfect amount you can just change gears without the clutch. But it's not worth it. Trucks and vans are easier I think?
    Oct 2010
    Daisy hill
    Eg5 si
    takes a while to get used to !!
    there is no real point for this unless your clutch is buggered,
    so if you want to learn this just drive down a back street and try it.
    just incase your clutch does fail oneday,
    oh and to start turn your car off, put it in first and turn your car on and accelarate ! hahaha
    good luck.
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    sounds like a clown trying to be cool.
    dont bother, youll prob destroy your gearbox trying.
    to see all of my build, checkout
    Newcomer Array
    Jul 2010
    Sydney
    EK gli
    tis possible ..you can find it on youtube =] heres how you do it http://www.youtube.com/watch?v=jLw0hAtOik4
  8. #8
    You know you want too... Array
    Sep 2005
    Sydney
    DC2R + VT750c2
    it is possible but only where there is no load on the box/engine... ie the road is perfectly flat and you are able to modulate the throttle to maintain the same speed throughout the process of changing gears...
    Your car's gearbox has what is called a synchromesh, which is designed to do that process for you, i would suggest you use them, as trying to do the above with the clutch will put undue stress on these items, eventually causing grindy gears and gearbox damage...
    - not removed by choice! - waiting for the next update to the saga
    http://www.ozhonda.com/forum/profile...=ignore&u=6316
