Results 1 to 12 of 13
    Jul 2010
    EK gli
    Changing LED in cluster
    i have an ek gli 1996. I think it has a stock cluster and i wanted to change the colour of it. I wasnt sure if it was the led itself or the dials that made it orange. Can you guys help me out by confirming and how i would do it if i wanted to make it green =D Thank you
    Jun 2006
    WA
    EG+CL9
    theres a DiY in the DiY forums ... search is your freind
    google will also tell you how
    Jul 2010
    EK gli
    Quote Originally Posted by TheSaint View Post
    but can it be done on an ek?
    can it be done to a dc2r??
    May 2009
    sydney
    R34 GTT
    pretty sure u can do it in any car just take out the cluster and change the LEDs
    106.3 Kw Atw
    Boostech Performance
    Aug 2009
    Front yard
    4WD 89 Concerto
    there just normal globes in the back that can easily be changed to led's on any car
    OEM parts whore
    Mar 2009
    Western Subs
    B16a2 EG2
    Yeh it's really easy just buy the globes from the markets. I always see them there small packs of 4 or 5 for around 8 dollars I believe. Then just replace them with the current bulbs making sure you get the polarity right and you will be fine
    "I love the smell of vtec in the morning!"
    Mar 2009
    Shitnee
    2 Door EK GLi
    A quick tip though, change 1 L.E.D at a time, and turn on the cluster to see if its working. Because there is a positive and a negative side, it may be put around the wrong way. I learnt the hard way by swearing 1000 times until I realised that this was the problem. So if it doesn't work first time, flip it around and see if it works.
    Also be sure not to damage the thin electric film that goes around the cluster. This gives power to the bulbs and if you damage it then you may **** up the lights for good.
    G'luck
    pretty sure its the bulbs that are colored for the cluster. dc2/4 are definately coloured bulbs. MAKE SURE you buy 360 degree bright bulbs dont cheap out on it they WILL look like shit. i have crappy LED ones installed in mine and it all diffrent level of brightness across my whole dash. if your ghetto you can get a texta to colour the bulbs, it works like tint lols
    Be water my friend.
    Jul 2010
    EK gli
    ty for all replies.. i hope its the bulbs that are coloured and not the film in the cluster.. will experiment sooon =]
    Aug 2008
    EK
    ive done it on my ek, got my LED's from jay car . about up spent like 13bucks
    B-serious m8
    Just buy the bulbs from eBay, I think the size you're after is T5
