there is a place for a 14mm headed bolt on the top right hand corner - near the fuel pressure regulator.
And there is a clip point on the gearbox itself (gold metal bracket in and around below the distributor area) - place for a U clip or similar to use a chain to lift.
gday, i think 16y4 is obd2, d15z1 is obd1 ?????????????? i am learning as i go, normally play with ford v8s. this is all new to me. and i need my car going, only rego 1 day before engine trouble. any help is greatly appreciated. is obd on-board diagnostic?
im not sure what it stands for but it effects all the plugs and harness type - if the engines are different obd than you will have to change over all the wiring as well
the y4 isnt vtec so im not sure if ECU will be an issue - P28 is a good ECU for non vtec stuff but it will show up a vtec CEL light
