Page 1 of 4 1234 LastLast
Results 1 to 12 of 40
    1995 Integra GSI Jap Spec
    My friends just bought a Integra GSI 1994 with 162000ks, he got a Rev check at it ended up being a First month 1995 Model. He was told by the Owner it was Imported from Japan. Just checking it the Jap Spec has a diff engine, cause it feels like it has Vtec power when revving high.
    Any ideas?
    All Honda's are imported from Japan. They are made there.
    The GSi model is an Australian delivered vehicle. Meaning it was sold to the Australian market.
    Jan 2010
    PnP Garage
    BREEZE
    You should have been able to see the date of manufacture stamped in the engine bay.
    part time potato
    Quote Originally Posted by Vvvtec View Post
    Yeah i found it, it Says 1/1995, and help about the Engine, or are the GSI stock engines just naturally Zippy, it revs out to 7000 rpm
    Jan 2010
    PnP Garage
    BREEZE
    Yeah, sounds like my teg. Build date is December 97 but it's a facelifted model and registered as 1998.
    What's the engine number on a JDM GSi? Wait have we actually worked out if it's an import? DC4's weren't badged as 'GSi' in Japan, were they? If there is no number after the last letter on the block stamp, it's a Jap motor. Ie: 'B18B' rather than the 'B18b2' that we get on Aus delivered motors.
    Anyway, it's no B18c. It will still go hard for what it is, it's really not a bad motor. Main thing that I feel let's the GSi down is the gearbox... It's pretty lame.
    part time potato
    Oct 2006
    Brisvegas
    DC2R
    GSI's are normally non-vtec.
    integras's are a high reving car.
    check the engine number.
    _________________
    What you mean N/A !!!!
    Dec 2009
    Canberra
    97 Integra
    Quote Originally Posted by sneakygreek View Post
    Gsi's redline at like 6900. They don't have V-tec but you still get a little boost in the higher rev range.
    It doesnt have a GSI badge at all, and wasnt debadged. Next time i see the car i will try Locate the Block stamp, where is it normally? is B18B Vtec at all or just revs good? I noticed that about the Gearbox aswell
    Feb 2010
    DC2R, S15
    b18b is NON vtec
    from wikipedia
    B18B1
    * NON-VTEC
    * Found in:
    o 1994-2001 Acura Integra "RS/LS/GS/SE" (DC4/DB7)
    o 1992-1996 JDM Honda Domani (MA5)
    o 1993-1994 JDM Honda Inta (DB7)
    o 1996-1999 JDM Honda Orthia (EL1)
    + Displacement: 1,834 cc (111.9 cu in)
    + Compression: 9.2:1
    + Bore: 81 mm (3.2 in)
    + Stroke: 89 mm (3.5 in)
    + Rod Length: 137.01 mm (5.394")
    + Rod/Stroke Ratio: 1.54
    + Power: 142 hp (106 kW) @ 6300 rpm & 130 ft·lbf (180 N·m) @ 5200 rpm
    + Redline: 6800 rpm (7200 rpm on JDM Domani)
    + Rev Limit: 7200 rpm
    + Transmission: Y80/S80
    + JDM version is marked B18B on the block without any number.
    + JDM version has a compression 9.4:1 where the usdm version is 9.2:1.
    + JDM versions higher comprsion rating results in higher hp and tq levels than the usdm version.
    http://en.wikipedia.org/wiki/Honda_B_engine#B18B1
    snapping 2nd..
    Jan 2010
    PnP Garage
    BREEZE
    To the left of the headers and down a bit on the block. I'd post a pic but I'm at work on my iPhone sorry! Can't miss it really.
    part time potato
    All i know is that it goes damn hard, even with me and my friend, who weights 94kg, Number Plate is 725-LUI if any1 sees it around
    Jan 2010
    PnP Garage
    BREEZE
    Lol you'd love a B18c if you think a GSi goes hard
    part time potato
