Results 1 to 7 of 7
    Angry Help with wiring!
    Hey,
    I tried installing a headunit into a 2002 Honda CRV. I can't work out where any of the wires connect to haha.
    Here's a diagram. If someone can tell me what's what. I will make out with you. Not really.
    PLEASE HELP!
    (Blu/Wht means Blue wires with white stripes =p)
    Dec 2010
    ED9 CRX
    Anyone else for FYI
    2002 Honda CRV Car Stereo Radio Wiring Diagram
    Radio Constant 12V+ Wire: White/Red
    Radio Switched Ignition 12V+ Wire: Yellow/Red or Yellow/Green
    Radio Ground Wire: Black
    Radio Illumination Dimmer Wire: Red/Black
    Radio Antenna Trigger Wire: N/A
    Radio Amplifier Turn On Wire: N/A
    Front Speaker Size: N/A
    Front Speaker Location: N/A
    Left Front Speaker Wire (+): Green/Black
    Left Front Speaker Wire (-): Light Green
    Right Front Speaker Wire (+): Green/Yellow
    Right Front Speaker Wire (-): Gray/Red
    Rear Speaker Size: N/A
    Rear Speaker Location: N/A
    Left Rear Speaker Wire (+): Blue/White
    Left Rear Speaker Wire (-): Blue/Black
    Right Rear Speaker Wire (+): Pink
    Right Rear Speaker Wire (-): Blue/Yellow
    http://www.modifiedlife.com/car-ster...002-honda-crv/
    Jaylah, the wiring diagram you were given was mostly correct, but you do have to connect the power antenna wire to get proper radio reception. That car as with most later model stuff with stubby roof-mounted antennae has an amplifier in the antenna that needs to be powered up. you may have noticed that AM reception in particular is woeful without it (repost if you want to know which wire)
    Quote Originally Posted by stereoguy View Post
    Yes please help me with the power wiring for the car antenna, my AM reception is woeful
    Aug 2005
    Gold Coast
    EG4 -> GD3 & RD
    Although this is an old thread, I would like to know which wire to power up the antenna too.
    Got my aftermarket device up and running but the radio drops in and out, very unstable.
    Please help..... Many thanks in advance.
    Oct 2015
    2002 Honda CR-V
Name:	Wiring Diagram.jpg
    just thought I would add this for anyone that needs it..
