Results 1 to 9 of 9
Hybrid View
    Prelude 92 Speedo
    The speedo on my 1992 Prelude tends to lose its way between ~ 40 to 70 kph. It seems to linger on the low side in this speed range, and then settles down once it gets above 70.
    Can someone advise whether this car is likely to have a cable speedo or electronic sensor, and whether there is likely to be a simple fix (hopefully that does not involve ripping the dash out).
    I expect that with GPS, I can get by without a speedo, but is a functioning speedo necessary for a RWC or passing a pit inspection.
    The car is a 1992 Prelude with the F22A1 SOHC 2.2 and a manual gearbox
    Green block gangster Array
    twin GX160's
    it will have an electric speedo
    the fault could be the VSS or the Speedo gauge
    I know this sounds a bit vague, but I think I have a few issues that may be VSS related.
    The car idles smoothly, but sometimes after a brief drive the CEL comes on, it begins to run roughly, and stalls at idle. Sometimes when this happens, the speedo needle will stick – i.e. the car is stationary but the needle is stuck on (say) 30km/h. Turn the ignition off and the needle drops – turn it back on and the needle returns to 30. Normally, after waiting a little while and restarting it settle down, the needle self-corrects and the CEL goes out.
    I have read that I can reset the ECU by removing the clock fuse – is this likely to help?
    I have read that I may be able to find the source of the problem by bridging the DTC terminal and counting the CEL flashes (?). Where can I find the terminal on a ’92 S.
    Where can I find the VSS on a F22A1 engine. Is the VSS something that can be easily removed, cleaned and re-inserted with the hope that all ills will be cured?
    My problem is that the car is unregistered so I cannot easily get it down to a garage. Observations and diagnosis are limited to idling in the drive way or a brief run to the end of the street.
    Before taking it to the pits, I wanted to fix the obvious problems (such as stalling and stuck needles), but I did not want to spend vast amounts of money on new VSS and ECU, etc, in case it ends up failing on a host of other problems – I have no experience with pit inspections but I image that things could be pretty tough for a 20yr old car with a vast amount of miles.
    twin GX160's
    read this thread and follow the instructions
    http://www.ozhonda.com/forum/showthr...gnostics-Codes
    you can find your SCS here
    http://b16a2.kicks-ass.net/diy/pgmfi...relude-001.jpg
    Thanks for the advice ECU-MAN
    How can I determine whether my car is OBDO, OBDI, or OBDII.
    I recently removed the battery, and I'm wondering whether the idle issue is because I have not 're-trained' the ECU
    twin GX160's
    92 prelude is OBDI
    when your engine lamp comes on and idles rough then somting is wrong. relearning the idle isnt going to help
    its a good idea to read thre ECU codes before resetting the ECU, post your results here if you wish
    92 prelude is OBDI
    ECU-MAN,
    I had reset the ECU and attempted the 'learning' before seeing your reply (although I note from your earlier link that OBDI does not require learning anyway). I then did the diagnostic check but did not get any error codes.
    I risked a quick run around the block, and the car did not stall or misbehave. The CEL did not come on and the speedo did not lock although it was at times a bit jerky and sticky, and tended to hunt a bit.
    While messing around, I noticed oil on the base of the distributor, so it looks like the O-ring has gone. Ran out of daylight and didn’t get a chance to look further, but I suppose oil coating the innards of the dist may contribute to rough running, but not affect ECU.
    Also, after researching a periodic starting problem, I suspect my main relay needs resoldering. But, I assume that this relay only affects starting and not running – does this sound right?
    twin GX160's
    you may have a faulty VSS, wait for the MIL to come on again and check your ECU for code 17.
    also I have seen on 92 ludes the Speedo itself fails casing wierd speed readings. there is a DIY on this as well.
    Thanks ECU-MAN
    Yep, all of erratic behaviour, sticking, wild fluctuations, reading low etc, turned out to be the VSS
