Results 1 to 3 of 3
    Jul 2007
    93' DA9
    CBR250r rear height adjustment?
    Hey guys, this has probably been said before or posted on how to do, so could someone send me in the right direction or help me out to adjust my rear supension to get the ride sitting a lil higher. ive pulled the tank off and the right side fairings, but my mate recons theres a lock nut ill need to loosen first before adjusting it?
    appreciate your help alot. thanks alot
    Scott
    Apr 2010
    Postman Bike
    there are many ways to jack the rear end up. however it wouldn't affect the riders seat much, it would make your handling alot more sensitive though.
    1. Use a c-spanner and set the pre-load to a higher setting (7 is the max)
    2. Replace the dog link in the rear suspension with a shorter one
    3. Change the rear shock. Apparently the CBR600F4 shock fits well needing only a few washers.
    Hi there, The best solution is to replace the dog link. They can be easily had at motorbike stores, but remember you will be throwing the geometry of the bike off. Why not lower the front?
