Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Hybrid View
    Knocking noise at full lock
    There's sometimes a continuous knocking noise at full lock. Any ideas of what may cause this? It's on a dc2r.
    Sounds like the CV boot is gone.
    Sep 2008
    Melbourne
    Kermit K20A
    Quote Originally Posted by garagedefend View Post
    i think you mean to say that the CV joint has gone. yes the boot has split, which in turn allows all the grease to get thrown out & stops lubricating the CV joint, but a f**ked CV boot will not knock. after a while the CV joints wear out & start knocking on full lock (in extreme cases it will knock while driving straight)
    do a nice easy check. full lock in both directions and see if it knocks. if it knocks only in one direction, one shaft is gone. if it knocks in both, then both shafts require replacing. if you are located in melbourne pm me and i can quote you on repairs
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
    Newcomer Array
    Aug 2009
    BNE
    あな
    is it more of a "clicking" metallic sound?
    fark. Another vague question that gets vague answers !
    To the op.....tell us this.
    1. Car is standard height OR lowered ? Springs or coilovers etc ? If so , when were these installed or last adjusted?
    2. How many ks on the chassis ?
    3. standard wheels or aftermarket wheels ?
    4. hit a pot hole or gutter recently ?
    Thanks stndrd, I'll get in contact and yes I'm in Melbourne.
    The car is mechanically standard, with no aftermarket suspension or wheels. Don't think it's a result of potholes.
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    You didn't answer, is it a 'knocking' or 'clicking'? Just need to verify.
  8. #8
    Sep 2008
    Melbourne
    Kermit K20A
    to some people a knock is a click & a click is a knock. at the end of the day its making a noise that he is concerned about
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
  9. #9
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Quote Originally Posted by stndrd View Post
    No. A click is a higher pitch sound than a knock and is 'clipped' off quickly. Knock is deeper and might resonate a little bit.
  10. #10
    Feb 2004
    Brisbane
    Honda's
    its your cd player
    11.41@119 mile ALL MOTOR street chassis
    K series parts whore
    FFamily
  11. #11
    Dec 2007
    melbourne
    eg5 si
    ^ lol
    yea sounds like your shafts gone mate.. do a quick easy check and shove your hand exacly behind the middle of the front wheel.. ahaha :P
  12. #12
    Newcomer Array
    Apr 2008
    Adelaide
    DC2&EF3
    SO maybe it's the problems of CV Join, try to replace one ASAP if they are fair enough of the price....^^
