Results 1 to 12 of 14
    Removing side intrusion bar
    Any one have advice on how to remove this? Its harden steel and it takes like 2min to cut 1mm with an air saw. In case your wondering I have full cage with side intrusion bars so I have no need for this bar.
    OZ Most Powerful K Series 279WHP
    101 MotorSport CRX
    Eastern Creek 1:35:1
    QR Clubman 54.7
    OZ Fastest FF
    Mar 2006
    Hillz District
    MY08 WRX G3
    sounds about right... unless you use some sort of laser cutting device...
    i think you posted the wrong picture btw
    ITs the correct picture, its the wide plate in the door that I would like to remove
    101 MotorSport CRX
    QR Clubman 54.7
    OZ Fastest FF
    Mar 2006
    Hillz District
    MY08 WRX G3
    dude thats barely a bar.
    umm one method i see people use is a die grinder, but with a cutting disc on the end. should work most efficiently
    It doesnt look like much but its seriously heavy. Angle grinder is always an option but there's a high chance I might go right through the skin of the door as its so close! thanks anyways
    101 MotorSport CRX
    QR Clubman 54.7
    OZ Fastest FF
    Pretty sure it's also spot glued to the door skin as well to prevent rattles (apart from strength). I can see you're trying to reduce as much weight as possible but is the risk to the skin worth it?
    Well pulled out the angle grinder and here are the results.
    It was actually pretty easy with the grinder, just had to be careful not to cut the leavers for the door mechanism.
    From full trim to what it is now I have saved easily 11kg per door, well worth the effort
    101 MotorSport CRX
    QR Clubman 54.7
    OZ Fastest FF
    Congrats! Thought the glue might have been more of a problem but looks like it wasn't holding on by much. Bet the heart was beating a bit faster when you were cutting through the bits close to the skin though.
    Now that I've taken another look at the bottom pic I can see that whoever put the glue strips on didn't even get it in the right place!
    Mar 2006
    Hillz District
    MY08 WRX G3
    the glue isnt a problem, trade specialists cut that glue like butter.
    and with the grinder, you need patience with it.
    atleast the job is half done now.hahah
    Smile
    door is almost complete
    101 MotorSport CRX
    QR Clubman 54.7
    OZ Fastest FF
    Mar 2006
    Hillz District
    MY08 WRX G3
    thats quite cool.
    awesome work with the doors mate
    I am about to attempt a similar thing, although I only have half cage so have to keep the intrusion bars, still gonna cut most of the front skin out though. Was just curious, what windows will you be using? Poly? If so where are you getting them done? I have been trying to find a place in VIC for a while, but no luck yet.
    WINTON PB: 1:36.30
    WAKEFIELD PB: 1:07.59
    Supported by: Hybrid Racing + Hardrace Australia
    MSC Performance FTW
