Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
    Oct 2003
    DA6K20A CD5H23T
    Quote Originally Posted by grifty View Post
    The markings are going to be on the timing cover and the crankshaft pulley.
    Download the service manual for your car and it should tell you how to adjust the timing.
    Heres the link. http://www.hondahookup.com/manuals/
    you have to register first.
    Also have you checked your spark plugs? if they are fouled with carbon there is going to be some hesitation when you press the accelerator.
    H22A timing marks are on the flywheel, pull the rubber plug from the front side of the bellhousing and you will see the marks
    Aug 2009
    Front yard
    4WD 89 Concerto
    Quote Originally Posted by stocky View Post
    Thanks for the correction mate, totally forgot about the H series.
    OEM parts whore
    Feb 2011
    Sydney, Riverwood
    Premium Octane
    changed my spark plugs along with engine oil. most of the hesitation on the accelerator is gone! =) jst guna adjust timing tomrow and see how it goes. thanks for the tips.
  4. #16
    Feb 2011
    Sydney, Riverwood
    Premium Octane
    Also, i had white 16" DC5 rims on it. I acquired some 17" pics below. but they seem to be a little too wide and whenever i go over fairly steep humps it scrapes the top a little... is there a way to tighten the suspension or something so its more stiff to prevent this happening? im fairly new to the whole concept of suspension...
