Recently lost clutch pedal feel, checked fluid very low, took it to Honda we found fluid around clutch pedal so means master cylinder leaking! Apparently I can get a kit so only about $150 to repair. Tip is clutch fluid is same as brake fluid attracts water! So then effects the rubber seals ect, do it every couple of years even though the manual never says to replace clutch fluid!
