I have oil leaking into the distributor. I have replaced the O-ring, so it appears to be a faulty inner seal.
Can this seal be replaced?
It looks like the shaft may lift straight out once you remove the cam drive and the plate that sits under the rotor button. However, I have removed all of the screws that appear to be holding this plate but it does not seem to want to come loose.
The 92 Helm manual does not seem to contain any description for pulling apart the distributor
92 Prelude 2.2 SOHC
