Results 1 to 8 of 8
    Aug 2009
    Brisbane
    EK1 Sedan
    Handbrake light wont go away - Help Please!
    I have recently swapped my cluster over for one with a tacho, now ever since the swap, 9 times out of 10, when i release the handbrake, the handbrake light still stays on...? Now I know its got nothing to do with the connection of the handbrake or the pressure button underneath it. As if you life the handbrake on and off you can see the light dim ever so slighly.
    Anyone else have a better incite to this then me....?
    Cheers.
    Not putting miles on your built cars is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend.
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    check connection to handbrake
    check brake fluid,
    check brake pads
    does car have abs?
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    Aug 2009
    Brisbane
    EK1 Sedan
    Car doesnt have abs, but cheers, ill check those things on my day off and see how it goes.
    Cheers.
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    For my CRX I'm pretty sure I have a wire short-circuit somewhere along the line, so sometimes it doesn't turn off, then it fixes itself and goes back to working etc. Would be a pain to try and find it though...
    Moderator Array
    Dec 2004
    Sydney, Australia
    Honda Civic VTi
    Quote Originally Posted by m.o.d.aus View Post
    You have a short. Handbrake light is activated by the handbrake mechanism. When you pull up on it you earth the connection and the light comes on. Therefore, somewhere you have an earth, possibly check your wiring on the cluster pins, or look under the dash for an earth that shouldn't be there. Also, check around the fusebox. Does your car have a front driver's seat connection under the seat for the seatbelt warning light. Check it too!
    Peter
    Still here. Still kickin'
    When my brake fluid was low the light was on. Same as the clutch fluid.
    Nov 2010
    South West Sydney
    EG
    Woah...on my way to uni today same thing happened. Freaked me out abit cause i started developing mental images of the brakes failing and me running into the back of a lamborghini or something. Sure enough, i had a quick look at the brake fluid level and it is just at the 'min' line. So a quick trip tomorrow to supercheap auto for me.
  8. #8
    Dec 2010
    Neverland
    Flying Carpet
    Hey Man Maybe Replace The Fuse
