Hannys 80,000km service + leaking gaskets + cam adjust?
Hi all,
As much as I hate these threads normally, unfortunately I need to know the average cost to expect for a 80,000km service at Hannys.
Normally I'd just ask Hannys, but the lady I spoke to on the phone had what seemed like basic english skills (although our connection was very bad - might have been that).
Also - do Integra VTiRs often need exhaust gaskets replaced? I think I either have a small hole in my exhaust, or a gasket leak. If I listen to my exhaust (stock), it sounds noisier and rougher (like air is leaking), and also if I listen to my engine from the engine bay, it seems a little louder... but the noise seems to disappear when the engine is under more load (ie up a hill).. weird
Lastly - has anyone here with a Integra VTiR had their CAMS adjusted by Hannys? Apparently they do this for $150 or so? Can anyone report the differences after it's performed? I've done a search but can't seem to pull up any information about it...
Thanks,
Tommo.
The lady u spoke to , was no doubt Mrs Robert ( the big boss's wife i think ?!?) - its always best to ask for "robert" or even better ask for "peter" next time ( he is a resident aussie that works there- nice bloke).
Exhaust gaskets shouldnt leak unlesss they are years old or have been hit (say you hit a speed bump underneath etc) .....i think the noise you describe could be another unrelated problem - best to get the guys to have a quick test ride and they can diagnose it best methinks.
and on the cam tune - i know a few people with varying car ( Si , ek4 vtir , b18b gsi etc) who have had their cams adjusted with decent results. WHAT robbie does is adjust the timing of the inlet + exhaust camshafts a few degrees either side to let in more air per induction stroke and also adjusts the ignition timing and adjusts fuel pressure slightly to take advantage + make abit more hp. It makes your idle alittle bit bubbly - and reports that ive heard, increases mid to top end pull very so slightly. For the money , its a decent mod i think.
Thanks for the information. I'll let them check it out, I think it's just an air leak somewhere along the line, but I'll defintely let them investigate. I was just investigating myself first so I have a general idea of what the problem could be. I know gaskets go in a lot of other cars, so thought that might have been the case here. My teg is only 5.5 years old, so I don't think it's that then.
Cam tune sounds decent - not sure if i'll like the lumpy idle, but I agree with you, for the cost I can't really go too wrong.
$150?? u sure............thats cheaper than what i've heard! (I think!)
I've heard varying amounts, and I didn't ask on the phone about it. I'll speak to them in more detail about the mods and costs when I go in on Monday.
I'm suprised they do this, for a place that hates mods so much
dont forget your timing belt (timing belt? or the other one..) cant remember, but most hondas need them replaced at 80-90k
Timing must be changed at 100,000k... but its always better to change them earlier.
80,000k is major service? i'd say rought $300-400 depending on what you need to replace as well... coz oil change is roughtly $120 already using mobile 1 synth. I got my timing belt changed for $250 plus all those other things in the service manual.
i though the cam adjustment thing was for slight gains in low to mid range - which consequently decreases top end range performance/effectiveness.
As far as I have experienced, this is correct.
so what gets done at the 80,000km service??
Green block gangster
Array
lots of stuff
do a search
well hmmmz
i cant remember wat i got done but the usuall plus new brake pads !
n the car bluebird is talkn about has been mine since april this year has been running awesome !
