hey guys! i got a jdm b16a obd1 in my eg
it was running excellent.. until the dizzy died =(
on the dizzy said TD44U so i went on search for a TD44U dizzy
but damn theyre rare as! a friend told me the TD43 is usable for the b16
so i bought one ... doesnt fit -__- but then was told the parts inside the td43 can b swapped into the td44 frame.. so i did it!! swapped all the parts.. but no luck car wouldnt turn on.
i then bought a TD44U dizzy from USA.. (not oem)
put it in.. CAR STARTS.. but then timing couldnt b read/adjusted properly..
only a very slight readin can b seen from the crank pulley.. so i used that.. n left the dizzy how it is sitting.. went for a drive.. it is so fkn weak.. so yeah i dno what to do next
ive been tryin to search for a oem td44u.. but not having luck
does anyone know what other dizzy i can use??
what should i do next about my car.
need help urgent
thanks in advance
