-open boot
-directly behind tail lights is a black cover undo the 4 clips that hold it in,
- Lift up the bootcarpet and cardboard and remove the black cover.
-Looking at the exposed rear shell look below and you will see two 10mm nuts apart from each other directly on either side,
there is another two on either ends but you will have to sort of bend the rear quater plastic to expose and reach, undo these 4 bolts.
-Remove the screw and clip in each end of the side of the bumper next to each quater panel.
- Underneath the rear bar is another two screws you will have to undo that bolts onto a piece of metal then to the chassis
When all that is complete you will be able to remove the bar but you will have to remove the number plate light plugs, it just twists off.
done....
