Ahhh, I see My bad, was a bit confusing there. I meant the two mufflers. CU2's don't have any high flow aftermarket coverters do they? Also, any rough estimations of how much it'd cost for a shop to build me a catback exhaust?
I think any metal cat should be okay as long as the pipe is weldable I guess.
Cost of a custom catback can be anything from 500-1000+ depending on what you get
Do your exhausts hang low. Not sure if its just mine i was looking at raising it a bit but then it would hit my sway bar. Im going to lower it soon so just gonna be annoyed if it keeps scraping.
I'll find out on wednesday if my cat/header hangs low, cause they are getting installed then
Digging up the past here!
I had a really stupid idea and i'm just wondering if anyone else beat me to it!
Have any of you tried to remove just the single rear muffler with the flange, if so, how was it?
I was keen to give it a shot just to see how it sounds then get a cheap a$$ straight pipe from the flange to stop it melting half my rear end
