Results 1 to 10 of 10
    225/50/16 on 16x6.5 DC5R Rim
    Do you guys thing that the lesser side-wall will help counteract the wideness of the Tyre?
    Considering some 225 semis that are FS.
    Dec 2010
    Sydney
    EP3r
    I think I was considering the same tires haha I was told that they will fit but not well and the tires would wobble if fitted to a dc5 rim..so killed my interest in them..
    ohh wow. 225 is pretty fat, especially for a 6.5" wide rim.
    on my DC5R, using stock wheels I am running 205/50/16 Dunlop Semi's. Seems to work pretty good.
    I think the 225 are a bit too wide, as on my CE28's I am using 225/45/17 and it seems okay!
    Maybe on the stock wheels, I'd push to max. 215/45 or 215/50
    yeah, I'm with frambo.. pretty sure it would have some mad wobbleness, as being to wide!
    Mainly worried about sidewall flex haha. Guys in the states are running 225 on their 16x6.6 ep wheels but they're not semis.
    I've driven a car with 225-50-16 tires on either 6 or 6.5" rims (stock tires were 205) and it felt weird, wobbly etc.
    The tires were not semi slicks, some dunlops if I recall correctly
    Jan 2008
    John St, Cabramatta
    DC5R
    I havnt used a tyre size calculator, but a sidewall of 225/50 (112.50) is going to be the same as 205/55 (112.75) From that simple calcualtion, it shows u the sidewall profile is be pretty much exactly the same. I wouldnt go a wider tyre at all; well that wide. If you can find semi's in 215/40/45/50 go for it, but 225 is too wide fora 6.5" imo.
    For me, I used 225/40 semi's on my 7.5" and 8" wheels.
  8. #8
    yeh im running 205/50/16 , best to use that size for the rim width. Let us know how you go with it though, would be interested to see good luck
    GR:33:KI
  9. #9
    Sep 2009
    South Brissy.
    MK6 Golf GTI
    ive used 225/50/16 on 16x7 rims on my dc4....
    i could not lower further than standard height unles i got spacers and rolled my guards alot heres a sample pic:
    Welcome Abourd
  10. #10
    Newcomer Array
    Feb 2006
    Melbourne
    lots of stuff
    Too wide for a 6.5" wheel. 225/50 is supposed to go on a 7.5" wide wheel. It feels wobbly because the tyre is too wide and the sidewall is overhanging the rim.
    Run 215/45 or a 205/50.
