Results 1 to 7 of 7
Thread: DC2 Suspension
    DC2 Suspension
    Recently installed DC2R shocks/springs due to my old set of shocks springs being squeaky everytime I go over humps or wavy roads/little bumps.
    But after a week of installing the stocks/springs the slightest of those noise came back, it seems like its due to the cold weather but when I first installed it, it all seemed good and quiet.
    was wondering if anything has the same problem or know what the problem is?
    Jan 2010
    Melbourne NE burbs
    DC2
    I'd start looking for worn bushings as your first point of call. They are the cheapest replacement before you start pulling it all apart again
    Aug 2010
    Integra GSI
    i was also wondering about this aswell.
    and to OP, how much you get all your springs for?
    Feb 2010
    DC2R, S15
    what carab said.
    also to fit dc2r sussy on a dc4 or dc2 you need DC2R lower control arms. around $150ish and then around $200 for the dc2r sussy setup
    snapping 2nd..
    lcas about $100, stock shocks/springs $150 minimum
    had to grind the rear lca's to make it fit though, it was a tad too fat
    dc2r shocks second hand?
    if it is, there is your problem.
    buy new.
    As soon as you lower a car below stock, you will be increase the amount of stress that is put on its suspension components (ie: bushings) and they will naturally crack/tear because of this added stress. Get them replaced. It can be costly to do all the bushings (front and back ~$6-800 for a energy suspension kit + labour) but it is WELL WORTH IT in the long run. Will also improve your alignment and overall handling!
    EG
