Results 1 to 10 of 10
    Engine in 1998 Honda Civic VTi Hatch?
    Hi All,
    Can someone please give me a definate answer?
    Does the AUSTRALIAN delivered 1998 Honda Civic VTi Hatch 2dr have the D16Y8 engine in it?
    Redbook says it does, but can someone on here please confirm for me. HERE
    Cheers,
    Dan.
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Yes it does
    Also... It's an EJ8 yeah?
    Jun 2006
    WA
    EG+CL9
    the coupe has D16y8, the sedan has D16y5
    we didnt get an EK - VTI hatch
    only cxi, gli and vti-r came in hatch
    the D16y8 is considered the best D series SOHC engine available
    it has a shorter ratio gearbox an intake manifold that is designed towards peak power rather than usable rev range
    the D16y5 isnt quite as peppy and doesnt have as good a gearbox
    the D16y1 (D16z6 usdm) from the EG civic VTI hatch is considered the second best D series SOHC engine available
    it has a similar gearbox to the D16y8 and a slightly better intake manifold design for all over the rev range
    so the 2dr coupe VTI is called an EJ8 and it did come with the D16y8
    D15b Turbo EG Sedan Build + CL9 Lux N/A Build
    http://www.ozhonda.com/forum/showthread.php?t=127680
    Thanks HEAPS for that information TheSaint and Dougie
    I now know the donor car I have to find in Australia "96-98 EJ8"
    Dont suppose you know the transmission code of the 5sp manual that it was mated with?
    Jun 2006
    WA
    EG+CL9
    S40 B000
    BUT the D16y5 also has the same code - and this DOES NOT have the better gear ratios - its very hard to tell them apart - and wreckers never know what the difference is - they will just sell you what fits (which is every D series gearbox lol)
    took me ages to find my S20 B000 box - but i eventually got one off a JDM D15b vtec engine
    So far I think i've worked out I need the L3 transmission (Cable)
  8. #8
    Apr 2009
    QLD
    ED Sedan
    Quote Originally Posted by Cheesy View Post
    for what car?
  9. #9
    75 Honda Civic (SB1)
  10. #10
    Apr 2009
    QLD
    ED Sedan
    L3 came from the ED civic, so it would bolt up to the above mentioned engine
