Results 1 to 12 of 21
    Dec 2008
    melb eastside
    mini subwoofer options
    hey guys, thinking of buying a small subwoofer for the car, just something light and small that i can just squeeze in on the corner of my dc2r boot..
    inb4 someone asks why bother with a sub if its a small size... i value my boot space.. as much as i want a proper sound system in my car, i dont see a point of turning my dc2r into a duff duff uleh car.
    at the moment its got alpine type r front splits, type r passenger 6x9s and some alpine head unit and an alpine bridgeable amp.
    has anyone tried these active powered subwoofers? these are small enough that it fits underneath the seats, and for the price, its a bargain. im not looking at anything over the top, just as long as i get some bass to balance the music..
    http://www.ebay.com.au/itm/BLITZ-AUD...#ht_3865wt_956
    theres also the alpine one but they are over $400, no thanks
    naturally i finished my set.
    Jun 2006
    WA
    EG+CL9
    supposing your amp is 4 channel and has the wattage to support it - i would get an alpine or pioneer 10" slimline subwoofer
    run the front splits off 2 of the channels on the amp and bridge the other 2 to run the subwoofer
    run the 6x9s off the headunit
    win
    Dec 2007
    melbourne
    eg5 si
    i actually want to know the same thing!! dont want to have a big sub hanging around.. but not too sure if the flat subs are any good.
    Mar 2010
    Adelaide, Australia
    '01 WRX
    slimline subs aren't too bad, they need more power though to sound decent. pioneer make the better slimline subs from the more common brands
    OVERRATED TO BE UNDERRATED
    LOLNOPE!
    Dec 2008
    melb eastside
    the amp is alpine 3522s, i just looked it up apparently its an old pos.
    it was used to run 2x 6'' clarions that was mounted on the rear parcel tray. it was a crap backyard job, wires hanging everywhere.
    i dont suppose the amp it will be enough to run both the front splits and a 10'' sub, cos the output is: "30wx2 into 4ohms @ .08% distortion or 40wx2 into 2ohms @ .3% distortion"
    what sort of 4 channel bridgeable amp would you recommend thesaint? any brand should be fine yea cos its only used to power the speakers?
    with the sub any other recommendations for anything below $150? possibly just buying the sub and diy the box?
    Jun 2006
    WA
    EG+CL9
    the setup i have at the moment is an Alpine PDX 4.100 amp (thats 100w per channel) - got mine for $300 posted on ebay brand new and it has served me well
    http://www.ebay.com.au/itm/ALPINE-PD...item1e5f140baa
    i have 2 of the channels bridged to run a pioneer slimline sub that is flush up against the back seat facing the boot
    i have the other 2 channels running some mb-quart splits in the front
    i have mb quart co-ax in the back running off the headunit
    i have an alpine 9886i for the headunit - got it brand new from alberts for around the same price
    http://www.ebay.com.au/itm/Alpine-98...item3a660924b3
    i intended to get the alpine type-r gear and alpine sub - but at the time they didnt make a slim/light subwoofer and the mb quarts was better quality at a lower price
    anything below 600w and you should be fine with an ebay 4awg amp wiring kit - just make sure it has a hella quality fuse
    i also bought my RCAs and line filter seperately - i got gold terminal sheilded gear
    all up the wiring was a tad pricey
    and finally - its all sitting in a box next to my pc waiting to go into my next car rofl
    i would just save up and be patient and do it properly man - so much better off in the long run
    Dec 2008
    melb eastside
    wow thanks for the info..
    thing is, i do have the money to spend on quality audio parts.. but i just cant justify spending that much money to practically ruin my dc2r..
    i just want something half decent to improve the audio quality from the current setup.. which basically involves powering the front splits externally and slapping a sub on
    i guess that 160w el cheapo subs isnt gonna cut it, so im prepared to pay a bit more for a good mini/slim sub... got anything in mind?
    Aug 2009
    Castle Hill, Sydney
    EK Civic
    I was in the same situation as you when I was installing my sound system in my EK.
    Another option you have, is to use a regular Sub and enclosure, but install it in a way which means it can be easily removed without any risk of damage to your gear.
    I have put some quick patch plugs inside the plastic panel in my boot, behind the access door to the tail lights, and that lets me unplug the sub when i need to take large things around (I am a keys player, i take 1.7m flight cases around)
    I have a 4x100RMS amp for my door speakers and a 300watt sub amp fitted with custom brackets under the seat, and that has given me pretty much the same flexibility that you are looking for.
    There is another option anyways.
    If not, the small kicker subs are pretty good!
    Oct 2010
    Integra
    I didn't even know these existed! This would be perfect for me. I like to keep my boot and parcel shelf clear, so that I can sleep in the back, and one of these would be helpful. Chuck the amp under one seat, and the sub under the other. I don't want ridiculous sound, just a bit more bass.
    Feb 2011
    92 B18 eg Civic
    I had this same issue in my car, I tried using a pioneer slim 10" sub (with top quality monoblock amp) and I found for the sub to fit under the seats the box has to be so incredibly slim it performs poorly. Box quality is nearly always more important that sub quality. I'm assuming a dc2r has the same under seat space as a eg civic so you wont be fitting much under there
    Feb 2011
    92 B18 eg Civic
    you might be better off investing in sound deadening or really bassy 6x9's in a good enclosure, you'd be suprised how much bass they can produce when in the right enclosure
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    [QUOTE=anzai;3020840]wow thanks for the info..
    /QUOTE]
    just how is this going to ruin the car? If you do it properly everything is reversible and can be transferred over to another car f you buy good stuff. For example, I've got a sub that cost me over 1200, a $1500 head unit and a $1000 procesor to go with it. I've got RCA cables that cost me 200 each, and I've got 3 of them. Along with about $3000 in amps and $1500 in speakers, for the front alone.
    But I've had them all for about 6 years, and they've been in about 3 different cars.
    Good quality gear will last you forever, and will sound great in the process.
    Now, I used to compete in sound quality comps, so you don't have to spend that much, but if you like music and you spend a fair bit of time in your car there's nothing wrong with it.
