Results 1 to 12 of 14
    Jul 2005
    FD1 Civic
    [DIY] Headrest Screen install FD civic
    Aim: to fit OA 5" screen to headrest
    Required: razor blade, marker, screen, zip ties, drill, " dremil tool "
    Steps:
    1: I already have had done one.. so im coping that... first mark out the for the screen cradle to fit.. in my case in the same spot as the last one
    2: Now u have marked it out.. grab a brand new razor blade and cut out inside the lines you have marked. then peel off the material ( it will be glued to a 5 mm layer of foam.. peel off the lot
    3: cut out about 30 - 40 mm of foam for the screen to fit in... if your not sure.. trial and error slowly get deeper
    4: Now cut out more foam.. to get the ends down to the polls... as wires have to go through them and the screen is fastened to them
    5: Fit the cradle and screen to make sure it will all fit with wiring behind it.. if it dont fit take out more foam..
    6: place zip ties around the polls. leave them open read to secure the cradle for the screen
    7: Cut the little pins off the back of the cradle.. to give roam for the bulky part of the zip tie to get through
    8: " the tricky part " ok now u need to drill a hole in the poll to poke the wire through use a center punch to put a dent in the poll for a place to start drilling... ( you will see why its the tricky bit lol )
    9: once the hole is done.. put the screen wire through the cradle and run the wire down the poll...
    10: leaving the wire though the cradle but with the screen out zip tie the cradle down to the head rest.. slowing pulling each corner tighter until u get what u want..
    11: once it is where u want it push the screen into the cradle and your done
    Comments :
    have not run the cableing through the seet yet but i will post up if i have any troubles doing so... but its pretty strate forward
    The car i have done this to is a new 2007 civic..
    Also not all screens have the same cradle and screen setup.. but i found the option Audio screens to be the best design... also the screen qual is second to none..
    Thanks guys
    i hope your projects go well
    Quote Originally Posted by AZ51LK
    when bruce banner gets angry and loses it, he turns into the incedible hulk...
    ...when the incredible hulk gets f*ckin pissed off and loses it, he turns into amurray
    http://images.cainer.net//uploads/peterbrock.jpg
    http://img67.imageshack.us/img67/586...nsigsh7ye2.jpg
    Ninja turtle Array
    Chloe
    Nice. Please do add the DIY for the wiring.
    Stocky CL9 - 1:17.2
    Jul 2005
    FD1 Civic
    just did the wiring through the seats.. will add to the DIY soon... next bit is taking apart the dash to get to the head unit
    Oct 2005
    Liverpool
    honda civic
    wow thats crazy man
    did u have a spare set of headrest just incase...?
    id be way too scared to do anything like this hahaha
    Jul 2005
    FD1 Civic
    nah man... i just had confidence on my side... and people i knew i could take it to if i went wrong.. but im happy with how they came out
    Jul 2005
    FD1 Civic
    they look neat in the car to
    omg thats sexy man!!!
    excellent job n write up....
    btw anyone know if i can or should do it to recaros??
    Jul 2005
    FD1 Civic
    yes u can.. my mate has done it to his buckets in his car.. they look pro
    any piks??
    Nov 2005
    OzHonda
    Monica
    thats sick
    Jan 2007
    Civic Vti
    Quote Originally Posted by amurray View Post
    I can't wait till you do the DIY getting to the head unit amurray!! U are the man!
