yeah im currenly running a gizzmo ibc. but it not realy usable to change wile im driving.
the link plus can control the boost, except for u need a serial link or tuning modual,
would realy need a full day at the track to dial it all in.
i do better times on 19psi then i do on 24psi. 24psi will wheel spinn my hoosier all the way through 3rd and some of 4th.
19psi give me more traction i think.
yeah try and get some boost by gear setup! on my car, on the street i could dead hook(not spin at all) in second gear and above. thats on a car that trapped 199kph.
so if you can have that sort of control on the drag strip, you can have your 10 psi first 15 second, 19 third and run 24 in top gear! or whatever boost you want, and grip, which will get you there quicker, perhaps faster, and not destroy your tires and engine from raping it on the limiter.
well rather then change my boost setup ive decided to do one better
get better tyres
going from
hoosier 225 50 15
to
Micky tomson 26"-10.5"-15" only just fits under the gards with the car raised
