Results 1 to 9 of 9
    Dec 2009
    QLD
    EG5
    B16 Revving High at Idle Problem?
    Hi guys,
    I recently took the throttle body off and iacv an gave them a clean with a throttle body cleaner, i put it all back together.
    But i accidentally knocked the throttle position sensor so the idle was bouncing up an down, I calibrated the tps back to standard 4.5v WOT 'wide open throttle' and .48v CT 'Closed throttle'
    And now i start the car up it will idle fine, but as soon as i touch the throttle it will rev to 3k at idle or when the clutch is engaged,
    the car drives normal when in gear an i just replaced the alternator belt today not sure if that changes anything.
    btw the car is a eg5 with a jdm b16a
    Any help would be very helpful
    Cheers
    Jan 2011
    Tasmania
    FN2R
    I'm having a similar problem with my d16y4 in my ek1.
    My revs surge from low to high on idle, could be the same problem as this.
    Newcomer Array
    May 2011
    Sydney
    Honda Civic EJ8
    did you warm up the car first?
    Dec 2009
    QLD
    EG5
    I didn't warm it up for the video, but once it is warmed up it still has same problem
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Quote Originally Posted by Woodzy View Post
    Nah,just clean ya IACV.
    Can anyone help here?
    Aug 2007
    Brisbane QLD
    ED-209
    sounds shit timmy, any luck yet?
    Anyways, we gotta meet up, swap cars for a drive. EM1 is the shiz with the new sussy
    くまくま━━━━━━ヽ( ・(ェ)・ )ノ━━━━━━ !!
    Jun 2006
    WA
    EG+CL9
    have you cleaned out and inspected the fast idle control valve - under the throttlebody?
    (FITV for short)
    D15b Turbo EG Sedan Build + CL9 Lux N/A Build
    http://www.ozhonda.com/forum/showthread.php?t=127680
  8. #8
    Dec 2009
    QLD
    EG5
    I have found the problem, the throttle rotor with the spring attached is getting stuck at 3,000rpm whenever i touch the throttle, The spring is very loose an need to be tight like this one - but the problem is the 11mm nut on the rotor just keeps spinning freely an wont come off, which makes it hard to re tension the spring. o well i gotta work over the weekend so ill attempt it again on Monday.
    Thanks for the help guys and Saint i don't have a fitv on my throttle body.
  9. #9
    Sep 2006
    Out in Nature
    91 eg5 b16a
    No FITV!
