I'm building an 97 ek civic hatch with a H22 and don't no what CVs to use? or what radator to use as i don't think the civic will cool the bigger engine?
The civic rad is fairly efficient, but if you really want, an oem fullsize will do the trick. You won't be able to run A/C & P/S with the h22 anyways so why not go fullsize?
For the CVs, sort of depends on what mounts you will be using. If you're getting hasport mounts, they have their own custom CVs you can look into, or DA integra ones are good lengths.
I just installed a h22a4 into eg hatch WITH power steering AND A/C.... though a/c needs the lines to be finished and regassed.....
